Lian Li
Blacknoise
UNI FAN SL120 ARGB
NB-eLoop X PWM B12xP ARGB
232 g
120 g
800 U/min
400 U/min
1900 U/min
58.5 CFM
77.9 CFM
99.5 m³/h
132.4 m³/h
1.67 mmH2O
3.02 mmH2O
31.0 dBA
28.4 dBA
Silber
Grau
3.4 V
2.4 V
412 U/min
294 U/min
98 U/min
138 U/min
1828 U/min
2002 U/min
23.2 CFM
+74.5 %
40.5 CFM
17.7 CFM
+40.5 %
24.9 CFM
15.8 CFM
+45.4 %
23.0 CFM
15.3 CFM
+37.3 %
21.0 CFM
39.5 m³/h
+74.4 %
68.9 m³/h
30.1 m³/h
+40.5 %
42.3 m³/h
26.9 m³/h
+45.4 %
39.1 m³/h
26.0 m³/h
+37.3 %
35.7 m³/h
0.40 mmH2O
+257.5 %
1.43 mmH2O
0.40 mmH2O
+102.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+25.0 %
+250.0 %
0.14 hPa
+100.0 %
+50.0 %
+25.0 %
38.8
-11.3 %
34.4
36.7
-0.5 %
36.5
36.1
-0.6 %
35.9
34.6
-4.2 %
36.1
