Lian Li
Alpenföhn
UNI FAN SL120 ARGB
Wing Boost 3
232 g
122 g
800 U/min
400 U/min
1900 U/min
1050 U/min
58.5 CFM
60.6 CFM
99.5 m³/h
103.0 m³/h
1.67 mmH2O
31.0 dBA
22.0 dBA
Silber
4.7 V
2.4 V
2.0 V
412 U/min
443 U/min
98 U/min
174 U/min
1828 U/min
1075 U/min
477 U/min
23.2 CFM
+112.0 %
49.3 CFM
17.7 CFM
+32.6 %
23.5 CFM
15.8 CFM
+48.4 %
23.5 CFM
15.3 CFM
+35.0 %
20.7 CFM
39.5 m³/h
+111.9 %
83.7 m³/h
30.1 m³/h
+32.6 %
39.9 m³/h
26.9 m³/h
+48.3 %
39.9 m³/h
26.0 m³/h
+35.0 %
35.1 m³/h
0.40 mmH2O
+307.5 %
1.63 mmH2O
0.40 mmH2O
+52.5 %
0.40 mmH2O
+25.0 %
0.4
0.4
+300.0 %
0.16 hPa
+50.0 %
+25.0 %
0.04
0.04
38.8
-13.0 %
44.6
36.7
-22.4 %
47.3
36.1
-21.0 %
45.7
34.6
-20.1 %
43.3
