Lian Li
Corsair
UNI FAN SL120 ARGB
LL140 RGB
232 g
210 g
800 U/min
600 U/min
1900 U/min
1300 U/min
58.5 CFM
51.5 CFM
99.5 m³/h
87.5 m³/h
1.67 mmH2O
1.52 mmH2O
31.0 dBA
25.0 dBA
Silber
Halbtransparent
2.4 V
2.9 V
412 U/min
226 U/min
98 U/min
378 U/min
1828 U/min
1319 U/min
23.2 CFM
+93.7 %
45.0 CFM
17.7 CFM
+60.2 %
28.4 CFM
15.8 CFM
+54.7 %
24.5 CFM
15.3 CFM
+72.7 %
26.4 CFM
39.5 m³/h
+93.7 %
76.5 m³/h
30.1 m³/h
+60.1 %
48.2 m³/h
26.9 m³/h
+54.6 %
41.6 m³/h
26.0 m³/h
+72.7 %
44.9 m³/h
0.40 mmH2O
+50.0 %
0.60 mmH2O
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
+50.0 %
+25.0 %
+25.0 %
+50.0 %
38.8
-9.0 %
35.3
36.7
-0.5 %
36.9
36.1
-5.8 %
34
34.6
-0.6 %
34.8
