Lian Li
Alphacool
UNI FAN SL120 ARGB
Eiszyklon Aurora Lux Pro ARGB
232 g
200 g
800 U/min
600 U/min
1900 U/min
1500 U/min
58.5 CFM
58.3 CFM
99.5 m³/h
99.3 m³/h
1.67 mmH2O
1.60 mmH2O
31.0 dBA
38.0 dBA
Silber
3.3 V
2.4 V
2.9 V
412 U/min
316 U/min
98 U/min
393 U/min
1828 U/min
1499 U/min
23.2 CFM
+97.8 %
46.0 CFM
17.7 CFM
+39.9 %
24.8 CFM
15.8 CFM
+33.8 %
21.2 CFM
15.3 CFM
+57.7 %
24.1 CFM
39.5 m³/h
+97.7 %
78.1 m³/h
30.1 m³/h
+39.9 %
42.1 m³/h
26.9 m³/h
+33.8 %
36.0 m³/h
26.0 m³/h
+57.7 %
41.0 m³/h
0.40 mmH2O
+77.5 %
0.4
0.4
0.40 mmH2O
+25.0 %
0.4
0.4
+75.0 %
0.04
0.04
+25.0 %
0.04
0.04
38.8
-11.3 %
34.4
36.7
-7.1 %
34.1
36.1
-8.3 %
33.1
34.6
-6.1 %
32.5
