Lian Li
Blacknoise
UNI FAN SL120 ARGB
B14x-P-BL PWM ARGB
232 g
202 g
800 U/min
1900 U/min
1500 U/min
0.5 W
2.9 W
58.5 CFM
110.0 CFM
99.5 m³/h
186.0 m³/h
1.67 mmH2O
2.30 mmH2O
31.0 dBA
29.6 dBA
Silber
4.3 V
2.4 V
412 U/min
335 U/min
98 U/min
154 U/min
1828 U/min
1487 U/min
23.2 CFM
+159.3 %
60.3 CFM
17.7 CFM
+87.7 %
33.2 CFM
15.8 CFM
+104.1 %
32.3 CFM
15.3 CFM
+117.3 %
33.2 CFM
39.5 m³/h
+159.2 %
102.4 m³/h
30.1 m³/h
+87.7 %
56.5 m³/h
26.9 m³/h
+104.1 %
54.9 m³/h
26.0 m³/h
+117.3 %
56.5 m³/h
0.40 mmH2O
+230.0 %
1.32 mmH2O
0.40 mmH2O
+230.0 %
1.32 mmH2O
0.40 mmH2O
+152.5 %
1.01 mmH2O
0.40 mmH2O
+205.0 %
1.22 mmH2O
+225.0 %
0.13 hPa
+225.0 %
0.13 hPa
+150.0 %
+200.0 %
0.12 hPa
38.8
-13.1 %
33.7
36.7
-1.9 %
37.4
36.1
-1.4 %
36.6
34.6
-3.9 %
36
