Lian Li
Cooler Master
UNI FAN SL120 ARGB
Sickleflow 140 ARGB
232 g
195 g
800 U/min
650 U/min
1900 U/min
1400 U/min
58.5 CFM
67.0 CFM
99.5 m³/h
113.8 m³/h
1.67 mmH2O
2.25 mmH2O
31.0 dBA
27.0 dBA
Silber
Halbtransparent
5.5 V
2.4 V
2.9 V
412 U/min
599 U/min
98 U/min
495 U/min
1828 U/min
1374 U/min
23.2 CFM
+95.0 %
45.3 CFM
17.7 CFM
+58.5 %
28.1 CFM
15.8 CFM
+64.7 %
26.1 CFM
15.3 CFM
+76.5 %
27.0 CFM
39.5 m³/h
+94.9 %
77.0 m³/h
30.1 m³/h
+58.5 %
47.7 m³/h
26.9 m³/h
+64.7 %
44.3 m³/h
26.0 m³/h
+76.5 %
45.9 m³/h
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
+25.0 %
+25.0 %
+25.0 %
+25.0 %
38.8
-8.5 %
35.5
36.7
-1.3 %
37.2
36.1
-9.1 %
32.8
34.6
-3.2 %
33.5
