Lian Li
Noctua
UNI FAN SL120 ARGB
NF-A14 FLX
232 g
210 g
800 U/min
900 U/min
1900 U/min
1200 U/min
58.5 CFM
68.0 CFM
99.5 m³/h
115.5 m³/h
1.67 mmH2O
1.51 mmH2O
31.0 dBA
19.2 dBA
Beige
Silber
Braun
Braun
4.6 V
2.4 V
4.2 V
412 U/min
381 U/min
98 U/min
469 U/min
1828 U/min
1199 U/min
23.2 CFM
+130.2 %
53.5 CFM
17.7 CFM
+86.1 %
33.0 CFM
15.8 CFM
+100.0 %
31.7 CFM
15.3 CFM
+97.0 %
30.1 CFM
39.5 m³/h
+130.1 %
90.9 m³/h
30.1 m³/h
+86.0 %
56.0 m³/h
26.9 m³/h
+100.0 %
53.8 m³/h
26.0 m³/h
+96.9 %
51.2 m³/h
0.40 mmH2O
+127.5 %
0.91 mmH2O
0.40 mmH2O
+127.5 %
0.91 mmH2O
0.40 mmH2O
+25.0 %
0.40 mmH2O
+33.3 %
0.30 mmH2O
+125.0 %
0.09 hPa
+125.0 %
0.09 hPa
+25.0 %
+33.3 %
0.03 hPa
38.8
-11.9 %
34.2
36.7
-13.8 %
42.6
36.1
-11.5 %
40.8
34.6
-13.3 %
39.9
