Arctic
Blacknoise
P14 PWM
B12x-PS-BL PWM ARGB
194 g
120 g
200 U/min
1700 U/min
1500 U/min
72.8 CFM
58.1 CFM
123.8 m³/h
98.7 m³/h
2.40 mmH2O
1.80 mmH2O
21.2 dBA
3.8 V
3.3 V
395 U/min
386 U/min
481 U/min
570 U/min
1733 U/min
1491 U/min
45.7 CFM
+24.8 %
36.6 CFM
27.1 CFM
+15.0 %
23.5 CFM
25.8 CFM
+7.6 %
23.9 CFM
27.0 CFM
+18.6 %
22.8 CFM
77.6 m³/h
+24.8 %
62.2 m³/h
46.0 m³/h
+15.0 %
40.0 m³/h
43.8 m³/h
+10.1 %
39.8 m³/h
45.9 m³/h
+18.6 %
38.7 m³/h
0.60 mmH2O
+86.7 %
1.12 mmH2O
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+77.5 %
+83.3 %
0.11 hPa
+75.0 %
+50.0 %
+75.0 %
30.7
-20.7 %
38.7
30.4
-19.8 %
37.9
30
-23.3 %
39.1
30.6
-17.3 %
37
