Arctic
NZXT
P14 PWM
F120 RGB
26 mm
194 g
205 g
200 U/min
500 U/min
1700 U/min
1800 U/min
0.4 W
1.8 W
72.8 CFM
50.2 CFM
123.8 m³/h
85.2 m³/h
2.40 mmH2O
2.70 mmH2O
27.5 dBA
3.8 V
4.7 V
4.4 V
395 U/min
827 U/min
481 U/min
703 U/min
1733 U/min
1924 U/min
447 U/min
45.7 CFM
+88.8 %
24.2 CFM
27.1 CFM
+42.8 %
18.9 CFM
25.8 CFM
+98.2 %
13.0 CFM
27.0 CFM
+44.4 %
18.7 CFM
77.6 m³/h
+88.8 %
41.1 m³/h
46.0 m³/h
+42.9 %
32.2 m³/h
43.8 m³/h
+98.2 %
22.1 m³/h
45.9 m³/h
+44.3 %
31.8 m³/h
0.60 mmH2O
+51.7 %
0.91 mmH2O
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
+50.0 %
0.09 hPa
+100.0 %
+100.0 %
+100.0 %
30.7
-19.2 %
24.8
30.4
30.4
30
-7.4 %
32.4
30.6
-3.3 %
29.6
  • 703
  • 903
  • 1103
  • 1303
  • 1503
  • 1703
  • 1903
