Arctic
Sharkoon
P14 PWM
Silent Storm PWM RGB Fan
194 g
135 g
200 U/min
400 U/min
1700 U/min
1400 U/min
2.2 W
72.8 CFM
123.8 m³/h
93.6 m³/h
2.40 mmH2O
20.4 dBA
3.8 V
3.6 V
395 U/min
585 U/min
481 U/min
561 U/min
1733 U/min
1374 U/min
513 U/min
45.7 CFM
+34.3 %
34.0 CFM
27.1 CFM
+39.0 %
19.5 CFM
25.8 CFM
+5.5 %
24.4 CFM
27.0 CFM
+25.4 %
21.5 CFM
77.6 m³/h
+34.3 %
57.8 m³/h
46.0 m³/h
+39.0 %
33.1 m³/h
43.8 m³/h
+5.5 %
41.5 m³/h
45.9 m³/h
+25.4 %
36.6 m³/h
0.60 mmH2O
+18.3 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
+16.7 %
+50.0 %
+50.0 %
+50.0 %
30.7
-3.2 %
31.7
30.4
-3.9 %
29.2
30
-8.3 %
27.5
30.6
-11.4 %
27.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
