Arctic
Corsair
P14 PWM
QL120 RGB
194 g
163 g
200 U/min
500 U/min
1700 U/min
1500 U/min
72.8 CFM
41.8 CFM
123.8 m³/h
2.40 mmH2O
1.55 mmH2O
26.0 dBA
Silber
Halbtransparent
3.8 V
3.0 V
395 U/min
245 U/min
481 U/min
472 U/min
1733 U/min
1600 U/min
45.7 CFM
+64.4 %
27.8 CFM
27.1 CFM
+31.4 %
20.6 CFM
25.8 CFM
+34.4 %
19.2 CFM
27.0 CFM
+56.7 %
17.2 CFM
77.6 m³/h
+64.4 %
47.2 m³/h
46.0 m³/h
+31.4 %
35.0 m³/h
43.8 m³/h
+34.4 %
32.6 m³/h
45.9 m³/h
+56.7 %
29.3 m³/h
0.60 mmH2O
+68.3 %
1.01 mmH2O
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.4
0.4
+66.7 %
+25.0 %
+25.0 %
0.04
0.04
30.7
-20.1 %
38.4
30.4
-20.6 %
38.3
30
-16.4 %
35.9
30.6
-14.5 %
35.8
