Arctic
MSI
P14 PWM
MEG Silent Gale P12
27.5 mm
194 g
209 g
200 U/min
1700 U/min
0.7 W
1.4 W
72.8 CFM
56.2 CFM
123.8 m³/h
95.5 m³/h
2.40 mmH2O
2.21 mmH2O
22.7 dBA
3.8 V
5.5 V
4.3 V
395 U/min
906 U/min
481 U/min
742 U/min
194 U/min
186 U/min
1733 U/min
1980 U/min
512 U/min
45.7 CFM
+46.7 %
31.1 CFM
27.1 CFM
+25.7 %
21.5 CFM
25.8 CFM
+16.8 %
22.1 CFM
27.0 CFM
+37.2 %
19.7 CFM
77.6 m³/h
+46.7 %
52.9 m³/h
46.0 m³/h
+25.7 %
36.6 m³/h
43.8 m³/h
+16.8 %
37.5 m³/h
45.9 m³/h
+37.4 %
33.4 m³/h
0.60 mmH2O
+51.7 %
0.91 mmH2O
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
+50.0 %
0.09 hPa
+100.0 %
+100.0 %
+100.0 %
30.7
-1.6 %
31.2
30.4
-12.6 %
34.8
30
-13.3 %
34.6
30.6
-7.6 %
33.1
