Arctic
Corsair
P14 PWM
LL140 RGB
194 g
210 g
200 U/min
600 U/min
1700 U/min
1300 U/min
72.8 CFM
51.5 CFM
123.8 m³/h
87.5 m³/h
2.40 mmH2O
1.52 mmH2O
25.0 dBA
Halbtransparent
3.8 V
2.9 V
395 U/min
226 U/min
481 U/min
378 U/min
1733 U/min
1319 U/min
45.7 CFM
+1.4 %
45.0 CFM
27.1 CFM
+4.8 %
28.4 CFM
25.8 CFM
+5.2 %
24.5 CFM
27.0 CFM
+2.2 %
26.4 CFM
77.6 m³/h
+1.4 %
76.5 m³/h
46.0 m³/h
+4.8 %
48.2 m³/h
43.8 m³/h
+5.3 %
41.6 m³/h
45.9 m³/h
+2.2 %
44.9 m³/h
0.6
0.6
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
0.06
0.06
+25.0 %
+25.0 %
+50.0 %
30.7
-13.0 %
35.3
30.4
-17.6 %
36.9
30
-11.8 %
34
30.6
-12.1 %
34.8
