Arctic
Cooler Master
P14 PWM
Sickleflow 140 ARGB
194 g
195 g
200 U/min
650 U/min
1700 U/min
1400 U/min
72.8 CFM
67.0 CFM
123.8 m³/h
113.8 m³/h
2.40 mmH2O
2.25 mmH2O
27.0 dBA
Halbtransparent
3.8 V
5.5 V
2.9 V
395 U/min
599 U/min
481 U/min
495 U/min
1733 U/min
1374 U/min
45.7 CFM
+0.8 %
45.3 CFM
27.1 CFM
+3.7 %
28.1 CFM
25.8 CFM
+1.2 %
26.1 CFM
27.01
27.01
77.6 m³/h
+0.8 %
77.0 m³/h
46.0 m³/h
+3.7 %
47.7 m³/h
43.8 m³/h
+1.1 %
44.3 m³/h
45.9
45.9
0.60 mmH2O
+20.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
+20.0 %
+25.0 %
+25.0 %
+25.0 %
30.7
-13.5 %
35.5
30.4
-18.3 %
37.2
30
-8.5 %
32.8
30.6
-8.7 %
33.5
