Corsair
Arctic
LL140 RGB
P12 PWM PST RGB 0dB
210 g
159 g
600 U/min
1300 U/min
51.5 CFM
48.8 CFM
87.5 m³/h
82.9 m³/h
1.52 mmH2O
1.85 mmH2O
25.0 dBA
Grau
Halbtransparent
Halbtransparent
4.0 V
2.9 V
2.9 V
226 U/min
380 U/min
378 U/min
532 U/min
1319 U/min
1985 U/min
45.0 CFM
+40.1 %
32.1 CFM
28.4 CFM
+18.5 %
23.9 CFM
24.5 CFM
+6.4 %
23.0 CFM
26.4 CFM
+19.7 %
22.1 CFM
76.5 m³/h
+40.1 %
54.6 m³/h
48.2 m³/h
+18.5 %
40.7 m³/h
41.6 m³/h
+6.4 %
39.1 m³/h
44.9 m³/h
+19.7 %
37.5 m³/h
0.60 mmH2O
+35.0 %
+22.0 %
+22.0 %
0.61
0.61
+33.3 %
+20.0 %
+20.0 %
0.06
0.06
35.3
-4.2 %
33.8
36.9
-14.4 %
31.6
34
-3.8 %
32.7
34.8
-7.8 %
32.1
