Corsair
Lian Li
LL140 RGB
UNI FAN SL-INF 120
210 g
210 g
600 U/min
1300 U/min
2100 U/min
3.0 W
51.5 CFM
61.3 CFM
87.5 m³/h
104.1 m³/h
1.52 mmH2O
2.66 mmH2O
25.0 dBA
29.0 dBA
Halbtransparent
3.5 V
2.9 V
226 U/min
913 U/min
378 U/min
742 U/min
290 U/min
298 U/min
1319 U/min
2134 U/min
886 U/min
45.0 CFM
+50.3 %
30.0 CFM
28.4 CFM
+19.0 %
23.8 CFM
24.5 CFM
+13.7 %
21.5 CFM
26.4 CFM
+18.5 %
22.3 CFM
76.5 m³/h
+50.3 %
50.9 m³/h
48.2 m³/h
+19.0 %
40.5 m³/h
41.6 m³/h
+13.7 %
36.6 m³/h
44.9 m³/h
+18.5 %
37.9 m³/h
0.60 mmH2O
+18.3 %
+42.0 %
+2.0 %
0.51 mmH2O
+19.6 %
0.51 mmH2O
+16.0 %
+39.3 %
+0.0 %
+20.0 %
35.3
-7.6 %
32.6
36.9
-9.2 %
33.5
34
-4.1 %
32.6
34.8
-3.7 %
33.5
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
