Corsair
Sharkoon
LL140 RGB
Silent Storm PWM RGB Fan
210 g
168 g
600 U/min
400 U/min
1300 U/min
1400 U/min
2.6 W
51.5 CFM
87.5 m³/h
121.9 m³/h
1.52 mmH2O
1.47 mmH2O
25.0 dBA
34.7 dBA
Halbtransparent
2.9 V
1.9 V
226 U/min
506 U/min
378 U/min
54 U/min
1319 U/min
1413 U/min
440 U/min
45.0 CFM
+9.6 %
41.1 CFM
28.4 CFM
+12.6 %
31.9 CFM
24.5 CFM
+25.2 %
30.7 CFM
26.4 CFM
+27.1 %
33.6 CFM
76.5 m³/h
+9.6 %
69.8 m³/h
48.2 m³/h
+12.7 %
54.3 m³/h
41.6 m³/h
+25.2 %
52.1 m³/h
44.9 m³/h
+27.2 %
57.1 m³/h
0.60 mmH2O
+35.0 %
+42.0 %
+42.0 %
+19.6 %
0.51 mmH2O
+33.3 %
+40.0 %
+40.0 %
+20.0 %
35.3
-7.6 %
32.6
36.9
-11.4 %
32.7
34
-2.4 %
33.2
34.8
-7.8 %
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
