Corsair
Fractal
LL140 RGB
Prisma AL-12PWM
210 g
167 g
600 U/min
500 U/min
1300 U/min
1.9 W
51.5 CFM
85.7 CFM
87.5 m³/h
145.7 m³/h
1.52 mmH2O
2.80 mmH2O
25.0 dBA
32.0 dBA
Halbtransparent
4.5 V
2.9 V
3.8 V
226 U/min
443 U/min
378 U/min
269 U/min
1319 U/min
2001 U/min
550 U/min
45.0 CFM
+42.5 %
31.6 CFM
28.4 CFM
+37.0 %
20.7 CFM
24.5 CFM
+17.5 %
20.8 CFM
26.4 CFM
+33.7 %
19.8 CFM
76.5 m³/h
+42.5 %
53.7 m³/h
48.2 m³/h
+36.9 %
35.2 m³/h
41.6 m³/h
+17.5 %
35.4 m³/h
44.9 m³/h
+33.6 %
33.6 m³/h
0.60 mmH2O
+35.0 %
+42.0 %
+42.0 %
0.61
0.61
+33.3 %
+40.0 %
+40.0 %
0.06
0.06
35.3
-0.6 %
35.5
36.9
-8.9 %
33.6
34
-6.2 %
31.9
34.8
-17.8 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
