Corsair
Blacknoise
LL140 RGB
NB-eLoop X PWM B12xP ARGB
210 g
120 g
600 U/min
400 U/min
1300 U/min
51.5 CFM
77.9 CFM
87.5 m³/h
132.4 m³/h
1.52 mmH2O
3.02 mmH2O
25.0 dBA
28.4 dBA
Grau
Halbtransparent
3.4 V
2.9 V
226 U/min
294 U/min
378 U/min
138 U/min
1319 U/min
2002 U/min
45.0 CFM
+11.0 %
40.5 CFM
28.4 CFM
+14.0 %
24.9 CFM
24.5 CFM
+6.4 %
23.0 CFM
26.4 CFM
+25.8 %
21.0 CFM
76.5 m³/h
+11.0 %
68.9 m³/h
48.2 m³/h
+13.9 %
42.3 m³/h
41.6 m³/h
+6.4 %
39.1 m³/h
44.9 m³/h
+25.8 %
35.7 m³/h
0.60 mmH2O
+138.3 %
1.43 mmH2O
+62.0 %
+22.0 %
+22.0 %
+133.3 %
0.14 hPa
+60.0 %
+20.0 %
+20.0 %
35.3
-2.5 %
34.4
36.9
-1.1 %
36.5
34
-5.3 %
35.9
34.8
-3.6 %
36.1
