Corsair
Lian Li
LL140 RGB
UNI FAN SL120 ARGB
210 g
232 g
600 U/min
800 U/min
1300 U/min
1900 U/min
51.5 CFM
58.5 CFM
87.5 m³/h
99.5 m³/h
1.52 mmH2O
1.67 mmH2O
25.0 dBA
31.0 dBA
Silber
Halbtransparent
2.9 V
2.4 V
226 U/min
412 U/min
378 U/min
98 U/min
1319 U/min
1828 U/min
45.0 CFM
+93.7 %
23.2 CFM
28.4 CFM
+60.2 %
17.7 CFM
24.5 CFM
+54.7 %
15.8 CFM
26.4 CFM
+72.7 %
15.3 CFM
76.5 m³/h
+93.7 %
39.5 m³/h
48.2 m³/h
+60.1 %
30.1 m³/h
41.6 m³/h
+54.6 %
26.9 m³/h
44.9 m³/h
+72.7 %
26.0 m³/h
0.60 mmH2O
+50.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+50.0 %
+25.0 %
+25.0 %
+50.0 %
35.3
-9.0 %
38.8
36.9
-0.5 %
36.7
34
-5.8 %
36.1
34.8
-0.6 %
34.6
