Corsair
Arctic
LL140 RGB
P14 PWM
210 g
194 g
600 U/min
200 U/min
1300 U/min
1700 U/min
51.5 CFM
72.8 CFM
87.5 m³/h
123.8 m³/h
1.52 mmH2O
2.40 mmH2O
25.0 dBA
Halbtransparent
3.8 V
2.9 V
226 U/min
395 U/min
378 U/min
481 U/min
1319 U/min
1733 U/min
45.0 CFM
+1.4 %
45.7 CFM
28.4 CFM
+4.8 %
27.1 CFM
24.5 CFM
+5.2 %
25.8 CFM
26.4 CFM
+2.2 %
27.0 CFM
76.5 m³/h
+1.4 %
77.6 m³/h
48.2 m³/h
+4.8 %
46.0 m³/h
41.6 m³/h
+5.3 %
43.8 m³/h
44.9 m³/h
+2.2 %
45.9 m³/h
0.6
0.6
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
0.06
0.06
+25.0 %
+25.0 %
+50.0 %
35.3
-13.0 %
30.7
36.9
-17.6 %
30.4
34
-11.8 %
30
34.8
-12.1 %
30.6
