Alphacool
Blacknoise
Eiszyklon Aurora Lux Pro ARGB
B12x-PS-BL PWM ARGB
200 g
120 g
600 U/min
1500 U/min
1500 U/min
58.3 CFM
58.1 CFM
99.3 m³/h
98.7 m³/h
1.60 mmH2O
1.80 mmH2O
38.0 dBA
21.2 dBA
3.3 V
3.3 V
2.9 V
316 U/min
386 U/min
393 U/min
570 U/min
1499 U/min
1491 U/min
46.0 CFM
+25.6 %
36.6 CFM
24.8 CFM
+5.2 %
23.5 CFM
21.2 CFM
+13.1 %
23.9 CFM
24.1 CFM
+6.0 %
22.8 CFM
78.1 m³/h
+25.6 %
62.2 m³/h
42.1 m³/h
+5.3 %
40.0 m³/h
36.0 m³/h
+10.6 %
39.8 m³/h
41.0 m³/h
+5.9 %
38.7 m³/h
+57.7 %
1.12 mmH2O
0.40 mmH2O
+77.5 %
+22.0 %
0.40 mmH2O
+77.5 %
+57.1 %
0.11 hPa
+75.0 %
+20.0 %
+75.0 %
34.4
-11.1 %
38.7
34.1
-10.0 %
37.9
33.1
-15.3 %
39.1
32.5
-12.2 %
37
