Alphacool
Cooler Master
Eiszyklon Aurora Lux Pro ARGB
Masterfan MF120 Halo
200 g
180 g
600 U/min
650 U/min
1500 U/min
1800 U/min
58.3 CFM
47.2 CFM
99.3 m³/h
1.60 mmH2O
38.0 dBA
30.0 dBA
Grau
Halbtransparent
3.3 V
3.3 V
2.9 V
316 U/min
166 U/min
393 U/min
590 U/min
1499 U/min
1792 U/min
46.0 CFM
+85.5 %
24.8 CFM
24.8 CFM
+24.5 %
19.9 CFM
21.2 CFM
+4.6 %
20.2 CFM
24.1 CFM
+40.0 %
17.2 CFM
78.1 m³/h
+85.5 %
42.1 m³/h
42.1 m³/h
+24.6 %
33.8 m³/h
36.0 m³/h
+14.6 %
31.4 m³/h
41.0 m³/h
+39.9 %
29.3 m³/h
+77.5 %
0.40 mmH2O
0.40 mmH2O
+102.5 %
+25.0 %
0.40 mmH2O
0.4
0.4
+75.0 %
+100.0 %
+25.0 %
0.04
0.04
34.4
-9.0 %
37.8
34.1
-6.3 %
36.4
33.1
-9.3 %
36.5
32.5
-8.7 %
35.6
