Alphacool
Lian Li
Eiszyklon Aurora Lux Pro ARGB
Uni Fan AL V2 120
28 mm
200 g
240 g
600 U/min
250 U/min
1500 U/min
0.7 W
2.1 W
58.3 CFM
77.3 CFM
99.3 m³/h
131.3 m³/h
1.60 mmH2O
2.97 mmH2O
38.0 dBA
28.7 dBA
Einzelreview
3.3 V
3.0 V
2.9 V
316 U/min
762 U/min
393 U/min
749 U/min
297 U/min
198 U/min
1499 U/min
820 U/min
46.0 CFM
+4.9 %
48.2 CFM
24.8 CFM
+62.3 %
40.2 CFM
21.2 CFM
+42.1 %
30.1 CFM
24.1 CFM
+70.7 %
41.2 CFM
78.1 m³/h
+4.9 %
81.9 m³/h
42.1 m³/h
+62.2 %
68.3 m³/h
36.0 m³/h
+42.1 %
51.1 m³/h
41.0 m³/h
+70.7 %
70.0 m³/h
+144.2 %
1.73 mmH2O
0.40 mmH2O
+282.5 %
1.53 mmH2O
+104.0 %
1.02 mmH2O
0.40 mmH2O
+307.5 %
1.63 mmH2O
+142.9 %
0.17 hPa
+275.0 %
0.15 hPa
+100.0 %
+300.0 %
0.16 hPa
34.4
-8.4 %
31.5
34.1
-14.7 %
29.1
33.1
-7.9 %
30.5
32.5
-7.4 %
30.1
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
