Alphacool
Alphacool
Eiszyklon Aurora Lux Pro ARGB
Rise Aurora
200 g
600 U/min
1500 U/min
6.6 W
58.3 CFM
90.7 CFM
99.3 m³/h
154.1 m³/h
1.60 mmH2O
2.20 mmH2O
38.0 dBA
38.4 dBA
3.3 V
2.9 V
2.9 V
316 U/min
883 U/min
393 U/min
553 U/min
331 U/min
145 U/min
1499 U/min
2108 U/min
677 U/min
46.0 CFM
+9.6 %
50.4 CFM
24.8 CFM
+7.6 %
26.7 CFM
21.2 CFM
+3.1 %
21.8 CFM
24.1 CFM
+17.5 %
20.5 CFM
78.1 m³/h
+9.6 %
85.6 m³/h
42.1 m³/h
+7.6 %
45.3 m³/h
36.0 m³/h
+3.1 %
37.1 m³/h
41.0 m³/h
+17.5 %
34.9 m³/h
+42.3 %
1.01 mmH2O
0.40 mmH2O
+50.0 %
0.60 mmH2O
+42.0 %
0.40 mmH2O
+102.5 %
+42.9 %
+50.0 %
+40.0 %
+100.0 %
34.4
-12.7 %
39.4
34.1
-13.0 %
39.2
33.1
-15.1 %
39
32.5
-13.8 %
37.7
  • 331
  • 531
  • 731
  • 931
  • 1131
  • 1331
  • 1531
  • 1731
  • 1931
