Alphacool
Blacknoise
Eiszyklon Aurora Lux Pro ARGB
NB-eLoop X PWM B12xP ARGB
200 g
120 g
600 U/min
400 U/min
1500 U/min
58.3 CFM
77.9 CFM
99.3 m³/h
132.4 m³/h
1.60 mmH2O
3.02 mmH2O
38.0 dBA
28.4 dBA
Grau
3.3 V
3.4 V
2.9 V
316 U/min
294 U/min
393 U/min
138 U/min
1499 U/min
2002 U/min
46.0 CFM
+13.3 %
40.5 CFM
24.8 CFM
+0.5 %
24.9 CFM
21.2 CFM
+8.6 %
23.0 CFM
24.1 CFM
+14.9 %
21.0 CFM
78.1 m³/h
+13.4 %
68.9 m³/h
42.1 m³/h
+0.5 %
42.3 m³/h
36.0 m³/h
+8.6 %
39.1 m³/h
41.0 m³/h
+14.8 %
35.7 m³/h
+101.4 %
1.43 mmH2O
0.40 mmH2O
+102.5 %
+22.0 %
0.40 mmH2O
+25.0 %
+100.0 %
0.14 hPa
+100.0 %
+20.0 %
+25.0 %
34.4
34.4
34.1
-6.6 %
36.5
33.1
-7.8 %
35.9
32.5
-10.0 %
36.1
