Alphacool
Eiszyklon Aurora Lux Pro ARGB
Silent Wings 3
200 g
137 g
600 U/min
150 U/min
1500 U/min
1450 U/min
58.3 CFM
50.5 CFM
99.3 m³/h
85.8 m³/h
1.60 mmH2O
1.79 mmH2O
38.0 dBA
16.4 dBA
3.3 V
4.1 V
2.9 V
3.9 V
316 U/min
393 U/min
206 U/min
244 U/min
1499 U/min
1411 U/min
46.0 CFM
+103.9 %
22.5 CFM
24.8 CFM
+24.5 %
19.9 CFM
21.2 CFM
+22.9 %
17.2 CFM
24.1 CFM
+43.9 %
16.8 CFM
78.1 m³/h
+103.9 %
38.3 m³/h
42.1 m³/h
+24.6 %
33.8 m³/h
36.0 m³/h
+22.9 %
29.3 m³/h
41.0 m³/h
+43.9 %
28.5 m³/h
+42.3 %
1.01 mmH2O
0.40 mmH2O
+77.5 %
+42.0 %
0.40 mmH2O
+25.0 %
+41.5 %
+74.1 %
+39.3 %
+22.6 %
34.4
-6.5 %
36.8
34.1
-18.4 %
41.8
33.1
-18.3 %
40.5
32.5
-20.0 %
40.6
