Alphacool
Lian Li
Eiszyklon Aurora Lux Pro ARGB
UNI FAN SL120 ARGB
200 g
232 g
600 U/min
800 U/min
1500 U/min
1900 U/min
58.3 CFM
58.5 CFM
99.3 m³/h
99.5 m³/h
1.60 mmH2O
1.67 mmH2O
38.0 dBA
31.0 dBA
Silber
3.3 V
2.9 V
2.4 V
316 U/min
412 U/min
393 U/min
98 U/min
1499 U/min
1828 U/min
46.0 CFM
+97.8 %
23.2 CFM
24.8 CFM
+39.9 %
17.7 CFM
21.2 CFM
+33.8 %
15.8 CFM
24.1 CFM
+57.7 %
15.3 CFM
78.1 m³/h
+97.7 %
39.5 m³/h
42.1 m³/h
+39.9 %
30.1 m³/h
36.0 m³/h
+33.8 %
26.9 m³/h
41.0 m³/h
+57.7 %
26.0 m³/h
+77.5 %
0.40 mmH2O
0.4
0.4
+25.0 %
0.40 mmH2O
0.4
0.4
+75.0 %
0.04
0.04
+25.0 %
0.04
0.04
34.4
-11.3 %
38.8
34.1
-7.1 %
36.7
33.1
-8.3 %
36.1
32.5
-6.1 %
34.6
