Alphacool
Cooler Master
Eiszyklon Aurora Lux Pro ARGB
Sickleflow 140 ARGB
200 g
195 g
600 U/min
650 U/min
1500 U/min
1400 U/min
58.3 CFM
67.0 CFM
99.3 m³/h
113.8 m³/h
1.60 mmH2O
2.25 mmH2O
38.0 dBA
27.0 dBA
Halbtransparent
3.3 V
5.5 V
2.9 V
2.9 V
316 U/min
599 U/min
393 U/min
495 U/min
1499 U/min
1374 U/min
46.0 CFM
+1.4 %
45.3 CFM
24.8 CFM
+13.3 %
28.1 CFM
21.2 CFM
+23.1 %
26.1 CFM
24.1 CFM
+11.9 %
27.0 CFM
78.1 m³/h
+1.4 %
77.0 m³/h
42.1 m³/h
+13.3 %
47.7 m³/h
36.0 m³/h
+23.1 %
44.3 m³/h
41.0 m³/h
+12.0 %
45.9 m³/h
+42.0 %
0.40 mmH2O
+25.0 %
0.5
0.5
0.40 mmH2O
+25.0 %
+40.0 %
+25.0 %
0.05
0.05
+25.0 %
34.4
-3.1 %
35.5
34.1
-8.3 %
37.2
33.1
-0.9 %
32.8
32.5
-3.0 %
33.5
