Alphacool
Thermaltake
Eiszyklon Aurora Lux Pro ARGB
200 g
212 g
600 U/min
500 U/min
1500 U/min
58.3 CFM
58.4 CFM
99.3 m³/h
99.1 m³/h
1.60 mmH2O
2.41 mmH2O
38.0 dBA
22.3 dBA
Grau
3.3 V
2.9 V
316 U/min
391 U/min
393 U/min
413 U/min
1499 U/min
1950 U/min
46.0 CFM
+38.5 %
33.2 CFM
24.8 CFM
+1.7 %
25.2 CFM
21.2 CFM
+15.6 %
24.5 CFM
24.1 CFM
+15.8 %
20.8 CFM
78.1 m³/h
+38.5 %
56.4 m³/h
42.1 m³/h
+1.7 %
42.8 m³/h
36.0 m³/h
+15.5 %
41.6 m³/h
41.0 m³/h
+15.9 %
35.4 m³/h
+159.2 %
1.84 mmH2O
0.40 mmH2O
+102.5 %
0.5
0.5
0.4
0.4
+157.8 %
0.18 hPa
+98.6 %
+2.0 %
+2.0 %
34.4
-8.0 %
37.4
34.1
-6.6 %
36.5
33.1
-8.1 %
36
32.5
-10.2 %
36.2
