Blacknoise
Arctic
B14x-P-BL PWM ARGB
P12 PWM
202 g
139 g
200 U/min
1500 U/min
1800 U/min
0.5 W
2.9 W
110.0 CFM
56.3 CFM
186.0 m³/h
2.30 mmH2O
2.20 mmH2O
29.6 dBA
Silber
4.3 V
3.0 V
335 U/min
207 U/min
154 U/min
547 U/min
1487 U/min
1748 U/min
60.3 CFM
+79.7 %
33.5 CFM
33.2 CFM
+43.1 %
23.2 CFM
32.3 CFM
+40.4 %
23.0 CFM
33.2 CFM
+54.4 %
21.5 CFM
102.4 m³/h
+79.6 %
57.0 m³/h
56.5 m³/h
+43.0 %
39.5 m³/h
54.9 m³/h
+40.4 %
39.1 m³/h
56.5 m³/h
+54.4 %
36.6 m³/h
1.32 mmH2O
+164.0 %
1.32 mmH2O
+116.4 %
1.01 mmH2O
+102.0 %
1.22 mmH2O
+100.0 %
0.13 hPa
+160.0 %
0.13 hPa
+116.7 %
+100.0 %
0.12 hPa
+100.0 %
33.7
-8.2 %
36.7
37.4
-7.2 %
34.7
36.6
-5.2 %
34.7
36
-4.4 %
34.4
