Blacknoise
Cooler Master
B14x-P-BL PWM ARGB
Masterfan MF120 Halo
202 g
180 g
650 U/min
1500 U/min
1800 U/min
0.5 W
2.9 W
110.0 CFM
47.2 CFM
186.0 m³/h
2.30 mmH2O
29.6 dBA
30.0 dBA
Grau
Halbtransparent
4.3 V
3.3 V
335 U/min
166 U/min
154 U/min
590 U/min
1487 U/min
1792 U/min
60.3 CFM
+143.3 %
24.8 CFM
33.2 CFM
+67.2 %
19.9 CFM
32.3 CFM
+59.6 %
20.2 CFM
33.2 CFM
+92.9 %
17.2 CFM
102.4 m³/h
+143.2 %
42.1 m³/h
56.5 m³/h
+67.2 %
33.8 m³/h
54.9 m³/h
+74.8 %
31.4 m³/h
56.5 m³/h
+92.8 %
29.3 m³/h
1.32 mmH2O
+230.0 %
0.40 mmH2O
1.32 mmH2O
+63.0 %
1.01 mmH2O
+152.5 %
0.40 mmH2O
1.22 mmH2O
+205.0 %
0.40 mmH2O
0.13 hPa
+225.0 %
0.13 hPa
+62.5 %
+150.0 %
0.12 hPa
+200.0 %
33.7
-10.8 %
37.8
37.4
-2.7 %
36.4
36.6
-0.3 %
36.5
36
-1.1 %
35.6
