Blacknoise
MSI
B14x-P-BL PWM ARGB
MEG Silent Gale P12
27.5 mm
202 g
209 g
1500 U/min
0.5 W
0.7 W
2.9 W
1.4 W
110.0 CFM
56.2 CFM
186.0 m³/h
95.5 m³/h
2.30 mmH2O
2.21 mmH2O
29.6 dBA
22.7 dBA
4.3 V
5.5 V
4.3 V
335 U/min
906 U/min
154 U/min
742 U/min
194 U/min
186 U/min
1487 U/min
1980 U/min
512 U/min
60.3 CFM
+93.6 %
31.1 CFM
33.2 CFM
+54.4 %
21.5 CFM
32.3 CFM
+46.4 %
22.1 CFM
33.2 CFM
+69.0 %
19.7 CFM
102.4 m³/h
+93.6 %
52.9 m³/h
56.5 m³/h
+54.4 %
36.6 m³/h
54.9 m³/h
+46.4 %
37.5 m³/h
56.5 m³/h
+69.2 %
33.4 m³/h
1.32 mmH2O
+45.1 %
0.91 mmH2O
1.32 mmH2O
+63.0 %
1.01 mmH2O
+24.7 %
1.22 mmH2O
+50.6 %
0.13 hPa
+44.4 %
0.09 hPa
0.13 hPa
+62.5 %
+25.0 %
0.12 hPa
+50.0 %
33.7
-7.4 %
31.2
37.4
-7.0 %
34.8
36.6
-5.5 %
34.6
36
-8.1 %
33.1
