Blacknoise
Blacknoise
B14x-P-BL PWM ARGB
NB-eLoop X PWM B12xP ARGB
202 g
120 g
400 U/min
1500 U/min
0.5 W
2.9 W
110.0 CFM
77.9 CFM
186.0 m³/h
132.4 m³/h
2.30 mmH2O
3.02 mmH2O
29.6 dBA
28.4 dBA
Grau
4.3 V
3.4 V
335 U/min
294 U/min
154 U/min
138 U/min
1487 U/min
2002 U/min
60.3 CFM
+48.6 %
40.5 CFM
33.2 CFM
+33.6 %
24.9 CFM
32.3 CFM
+40.4 %
23.0 CFM
33.2 CFM
+58.3 %
21.0 CFM
102.4 m³/h
+48.6 %
68.9 m³/h
56.5 m³/h
+33.6 %
42.3 m³/h
54.9 m³/h
+40.4 %
39.1 m³/h
56.5 m³/h
+58.3 %
35.7 m³/h
1.32 mmH2O
+8.3 %
1.43 mmH2O
1.32 mmH2O
+63.0 %
1.01 mmH2O
+65.6 %
1.22 mmH2O
+144.0 %
0.13 hPa
+7.7 %
0.14 hPa
0.13 hPa
+62.5 %
+66.7 %
0.12 hPa
+140.0 %
33.7
-2.0 %
34.4
37.4
-2.4 %
36.5
36.6
-1.9 %
35.9
36
-0.3 %
36.1
