Blacknoise
Noctua
B14x-P-BL PWM ARGB
NF-A14 FLX
202 g
210 g
900 U/min
1500 U/min
1200 U/min
0.5 W
2.9 W
110.0 CFM
68.0 CFM
186.0 m³/h
115.5 m³/h
2.30 mmH2O
1.51 mmH2O
29.6 dBA
19.2 dBA
Beige
Braun
Braun
4.3 V
4.6 V
4.2 V
335 U/min
381 U/min
154 U/min
469 U/min
1487 U/min
1199 U/min
60.3 CFM
+12.7 %
53.5 CFM
33.2 CFM
+0.9 %
33.0 CFM
32.3 CFM
+2.0 %
31.7 CFM
33.2 CFM
+10.3 %
30.1 CFM
102.4 m³/h
+12.7 %
90.9 m³/h
56.5 m³/h
+0.9 %
56.0 m³/h
54.9 m³/h
+2.0 %
53.8 m³/h
56.5 m³/h
+10.4 %
51.2 m³/h
1.32 mmH2O
+45.1 %
0.91 mmH2O
1.32 mmH2O
+45.1 %
0.91 mmH2O
1.01 mmH2O
+102.0 %
1.22 mmH2O
+306.7 %
0.30 mmH2O
0.13 hPa
+44.4 %
0.09 hPa
0.13 hPa
+44.4 %
0.09 hPa
+100.0 %
0.12 hPa
+300.0 %
0.03 hPa
33.7
-1.5 %
34.2
37.4
-12.2 %
42.6
36.6
-10.3 %
40.8
36
-9.8 %
39.9
