Cooler Master
Arctic
Sickleflow 140 ARGB
P12 PWM
195 g
139 g
650 U/min
200 U/min
1400 U/min
1800 U/min
67.0 CFM
56.3 CFM
113.8 m³/h
2.25 mmH2O
2.20 mmH2O
27.0 dBA
Silber
Halbtransparent
5.5 V
2.9 V
3.0 V
599 U/min
207 U/min
495 U/min
547 U/min
1374 U/min
1748 U/min
45.3 CFM
+35.1 %
33.5 CFM
28.1 CFM
+20.8 %
23.2 CFM
26.1 CFM
+13.3 %
23.0 CFM
27.0 CFM
+25.4 %
21.5 CFM
77.0 m³/h
+35.1 %
57.0 m³/h
47.7 m³/h
+20.8 %
39.5 m³/h
44.3 m³/h
+13.3 %
39.1 m³/h
45.9 m³/h
+25.4 %
36.6 m³/h
0.5
0.5
+22.0 %
0.5
0.5
+22.0 %
0.05
0.05
+20.0 %
0.05
0.05
+20.0 %
35.5
-3.3 %
36.7
37.2
-6.7 %
34.7
32.8
-5.5 %
34.7
33.5
-2.6 %
34.4
