Cooler Master
Cooler Master
Sickleflow 140 ARGB
Masterfan MF120 Halo
195 g
180 g
650 U/min
650 U/min
1400 U/min
1800 U/min
67.0 CFM
47.2 CFM
113.8 m³/h
2.25 mmH2O
27.0 dBA
30.0 dBA
Grau
Halbtransparent
Halbtransparent
5.5 V
3.3 V
2.9 V
599 U/min
166 U/min
495 U/min
590 U/min
1374 U/min
1792 U/min
45.3 CFM
+83.0 %
24.8 CFM
28.1 CFM
+41.1 %
19.9 CFM
26.1 CFM
+28.8 %
20.2 CFM
27.0 CFM
+56.7 %
17.2 CFM
77.0 m³/h
+82.9 %
42.1 m³/h
47.7 m³/h
+41.1 %
33.8 m³/h
44.3 m³/h
+41.1 %
31.4 m³/h
45.9 m³/h
+56.7 %
29.3 m³/h
+25.0 %
0.40 mmH2O
+62.0 %
+25.0 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
+60.0 %
+25.0 %
+25.0 %
35.5
-6.1 %
37.8
37.2
-2.2 %
36.4
32.8
-10.1 %
36.5
33.5
-5.9 %
35.6
