Cooler Master
Lian Li
Sickleflow 140 ARGB
UNI FAN SL-INF 120
195 g
210 g
650 U/min
1400 U/min
2100 U/min
3.0 W
67.0 CFM
61.3 CFM
113.8 m³/h
104.1 m³/h
2.25 mmH2O
2.66 mmH2O
27.0 dBA
29.0 dBA
Halbtransparent
5.5 V
3.5 V
2.9 V
599 U/min
913 U/min
495 U/min
742 U/min
290 U/min
298 U/min
1374 U/min
2134 U/min
886 U/min
45.3 CFM
+51.3 %
30.0 CFM
28.1 CFM
+17.8 %
23.8 CFM
26.1 CFM
+21.0 %
21.5 CFM
27.0 CFM
+21.1 %
22.3 CFM
77.0 m³/h
+51.3 %
50.9 m³/h
47.7 m³/h
+17.8 %
40.5 m³/h
44.3 m³/h
+21.0 %
36.6 m³/h
45.9 m³/h
+21.1 %
37.9 m³/h
+42.0 %
+42.0 %
+2.0 %
0.51 mmH2O
+2.0 %
0.51 mmH2O
+39.3 %
+39.3 %
+0.0 %
+0.0 %
35.5
-8.2 %
32.6
37.2
-9.9 %
33.5
32.8
-0.6 %
32.6
33.5
33.5
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
