Cooler Master
Thermalright
Sickleflow 140 ARGB
TL-B12 Extreme
25.6 mm
195 g
215 g
650 U/min
550 U/min
1400 U/min
3150 U/min
1.0 W
4.2 W
67.0 CFM
112.0 CFM
113.8 m³/h
190.3 m³/h
2.25 mmH2O
5.00 mmH2O
27.0 dBA
40.5 dBA
Rot, Weiß
Halbtransparent
5.5 V
1.8 V
2.9 V
1.4 V
599 U/min
293 U/min
495 U/min
163 U/min
1374 U/min
2857 U/min
554 U/min
45.3 CFM
+43.4 %
31.6 CFM
28.1 CFM
+18.3 %
23.7 CFM
26.1 CFM
+16.9 %
22.3 CFM
27.0 CFM
+28.2 %
21.1 CFM
77.0 m³/h
+43.4 %
53.7 m³/h
47.7 m³/h
+18.4 %
40.3 m³/h
44.3 m³/h
+16.9 %
37.9 m³/h
45.9 m³/h
+28.2 %
35.8 m³/h
+42.0 %
+42.0 %
+62.0 %
+42.0 %
+40.0 %
+40.0 %
+60.0 %
+40.0 %
35.5
-8.7 %
32.4
37.2
-16.4 %
31.1
32.8
-0.9 %
32.5
33.5
-9.0 %
30.5
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
