Cooler Master
Corsair
Sickleflow 140 ARGB
ML 120 RGB Elite
195 g
186 g
650 U/min
450 U/min
1400 U/min
1.6 W
67.0 CFM
58.1 CFM
113.8 m³/h
98.7 m³/h
2.25 mmH2O
2.90 mmH2O
27.0 dBA
30.4 dBA
Halbtransparent
5.5 V
3.0 V
2.9 V
599 U/min
510 U/min
495 U/min
450 U/min
169 U/min
84 U/min
1374 U/min
1993 U/min
45.3 CFM
+28.6 %
35.2 CFM
28.1 CFM
+16.0 %
24.2 CFM
26.1 CFM
+10.0 %
23.7 CFM
27.0 CFM
+26.8 %
21.3 CFM
77.0 m³/h
+28.5 %
59.9 m³/h
47.7 m³/h
+16.1 %
41.1 m³/h
44.3 m³/h
+9.9 %
40.3 m³/h
45.9 m³/h
+26.8 %
36.2 m³/h
+42.0 %
+22.0 %
+22.0 %
+42.0 %
+40.0 %
+20.0 %
+20.0 %
+40.0 %
35.5
-19.7 %
28.5
37.2
-20.7 %
29.5
32.8
-13.1 %
28.5
33.5
-17.0 %
27.8
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
