Cooler Master
Corsair
Sickleflow 140 ARGB
QL120 RGB
195 g
163 g
650 U/min
500 U/min
1400 U/min
1500 U/min
67.0 CFM
41.8 CFM
113.8 m³/h
2.25 mmH2O
1.55 mmH2O
27.0 dBA
26.0 dBA
Silber
Halbtransparent
Halbtransparent
5.5 V
3.0 V
2.9 V
599 U/min
245 U/min
495 U/min
472 U/min
1374 U/min
1600 U/min
45.3 CFM
+63.1 %
27.8 CFM
28.1 CFM
+36.3 %
20.6 CFM
26.1 CFM
+35.9 %
19.2 CFM
27.0 CFM
+56.7 %
17.2 CFM
77.0 m³/h
+63.1 %
47.2 m³/h
47.7 m³/h
+36.3 %
35.0 m³/h
44.3 m³/h
+35.9 %
32.6 m³/h
45.9 m³/h
+56.7 %
29.3 m³/h
+102.0 %
1.01 mmH2O
0.5
0.5
0.5
0.5
+25.0 %
0.40 mmH2O
+100.0 %
0.05
0.05
0.05
0.05
+25.0 %
35.5
-7.6 %
38.4
37.2
-2.9 %
38.3
32.8
-8.6 %
35.9
33.5
-6.4 %
35.8
