Cooler Master
Sickleflow 140 ARGB
Light Wings 140 PWM HS
195 g
266 g
650 U/min
250 U/min
1400 U/min
2200 U/min
1.9 W
4.7 W
67.0 CFM
71.7 CFM
113.8 m³/h
121.8 m³/h
2.25 mmH2O
2.30 mmH2O
27.0 dBA
31.0 dBA
Halbtransparent
5.5 V
3.0 V
2.9 V
599 U/min
565 U/min
495 U/min
556 U/min
1374 U/min
2264 U/min
241 U/min
45.3 CFM
+12.9 %
40.1 CFM
28.1 CFM
+14.9 %
24.4 CFM
26.1 CFM
+16.0 %
22.5 CFM
27.0 CFM
+11.9 %
24.1 CFM
77.0 m³/h
+12.9 %
68.2 m³/h
47.7 m³/h
+14.9 %
41.5 m³/h
44.3 m³/h
+16.0 %
38.2 m³/h
45.9 m³/h
+12.0 %
41.0 m³/h
+266.0 %
1.83 mmH2O
+22.0 %
+22.0 %
+22.0 %
+260.0 %
0.18 hPa
+20.0 %
+20.0 %
+20.0 %
35.5
-28.2 %
25.5
37.2
-28.2 %
26.7
32.8
-21.6 %
25.7
33.5
-23.9 %
25.5
  • 556
  • 756
  • 956
  • 1156
  • 1356
  • 1556
  • 1756
  • 1956
  • 2156
