Cooler Master
Sickleflow 140 ARGB
Light Wings PWM HS
195 g
210 g
650 U/min
300 U/min
1400 U/min
2500 U/min
1.4 W
5.4 W
67.0 CFM
52.3 CFM
113.8 m³/h
88.9 m³/h
2.25 mmH2O
2.60 mmH2O
27.0 dBA
31.0 dBA
Halbtransparent
5.5 V
2.9 V
599 U/min
608 U/min
495 U/min
565 U/min
1374 U/min
2489 U/min
248 U/min
45.3 CFM
+39.3 %
32.5 CFM
28.1 CFM
+51.9 %
18.5 CFM
26.1 CFM
+37.6 %
18.9 CFM
27.0 CFM
+52.5 %
17.7 CFM
77.0 m³/h
+39.2 %
55.3 m³/h
47.7 m³/h
+51.9 %
31.4 m³/h
44.3 m³/h
+37.6 %
32.2 m³/h
45.9 m³/h
+52.5 %
30.1 m³/h
+42.0 %
0.5
0.5
+25.0 %
0.40 mmH2O
0.5
0.5
+40.0 %
0.05
0.05
+25.0 %
0.05
0.05
35.5
-5.1 %
33.7
37.2
-15.1 %
31.6
32.8
-2.4 %
32
33.5
-8.4 %
30.7
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
