Cooler Master
Sickleflow 140 ARGB
Light Wings PWM
195 g
205 g
650 U/min
100 U/min
1400 U/min
1700 U/min
0.8 W
4.6 W
67.0 CFM
41.5 CFM
113.8 m³/h
70.5 m³/h
2.25 mmH2O
1.66 mmH2O
27.0 dBA
20.6 dBA
Halbtransparent
5.5 V
2.9 V
599 U/min
369 U/min
495 U/min
350 U/min
1374 U/min
1680 U/min
134 U/min
45.3 CFM
+34.2 %
33.8 CFM
28.1 CFM
+41.1 %
19.9 CFM
26.1 CFM
+34.2 %
19.4 CFM
27.0 CFM
+46.2 %
18.5 CFM
77.0 m³/h
+34.1 %
57.4 m³/h
47.7 m³/h
+41.1 %
33.8 m³/h
44.3 m³/h
+34.2 %
33.0 m³/h
45.9 m³/h
+46.2 %
31.4 m³/h
+42.0 %
0.5
0.5
0.5
0.5
+22.0 %
+40.0 %
0.05
0.05
0.05
0.05
+20.0 %
35.5
-16.9 %
29.5
37.2
-20.4 %
29.6
32.8
-4.0 %
31.5
33.5
-3.3 %
32.4
  • 350
  • 550
  • 750
  • 950
  • 1150
  • 1350
  • 1550
