Cooler Master
Blacknoise
Sickleflow 140 ARGB
NB-eLoop X PWM B12xP ARGB
195 g
120 g
650 U/min
400 U/min
1400 U/min
67.0 CFM
77.9 CFM
113.8 m³/h
132.4 m³/h
2.25 mmH2O
3.02 mmH2O
27.0 dBA
28.4 dBA
Grau
Halbtransparent
5.5 V
3.4 V
2.9 V
599 U/min
294 U/min
495 U/min
138 U/min
1374 U/min
2002 U/min
45.3 CFM
+11.8 %
40.5 CFM
28.1 CFM
+12.8 %
24.9 CFM
26.1 CFM
+13.3 %
23.0 CFM
27.0 CFM
+28.6 %
21.0 CFM
77.0 m³/h
+11.8 %
68.9 m³/h
47.7 m³/h
+12.8 %
42.3 m³/h
44.3 m³/h
+13.3 %
39.1 m³/h
45.9 m³/h
+28.6 %
35.7 m³/h
+186.0 %
1.43 mmH2O
+62.0 %
+22.0 %
0.5
0.5
+180.0 %
0.14 hPa
+60.0 %
+20.0 %
0.05
0.05
35.5
-3.1 %
34.4
37.2
-1.9 %
36.5
32.8
-8.6 %
35.9
33.5
-7.2 %
36.1
