Cooler Master
Sickleflow 140 ARGB
Silent Wings 3
195 g
137 g
650 U/min
150 U/min
1400 U/min
1450 U/min
67.0 CFM
50.5 CFM
113.8 m³/h
85.8 m³/h
2.25 mmH2O
1.79 mmH2O
27.0 dBA
16.4 dBA
Halbtransparent
5.5 V
4.1 V
2.9 V
3.9 V
599 U/min
495 U/min
206 U/min
244 U/min
1374 U/min
1411 U/min
45.3 CFM
+101.1 %
22.5 CFM
28.1 CFM
+41.1 %
19.9 CFM
26.1 CFM
+51.2 %
17.2 CFM
27.0 CFM
+61.1 %
16.8 CFM
77.0 m³/h
+101.0 %
38.3 m³/h
47.7 m³/h
+41.1 %
33.8 m³/h
44.3 m³/h
+51.2 %
29.3 m³/h
45.9 m³/h
+61.1 %
28.5 m³/h
+102.0 %
1.01 mmH2O
+42.0 %
+42.0 %
0.5
0.5
+98.1 %
+39.3 %
+39.3 %
+2.0 %
35.5
-3.5 %
36.8
37.2
-11.0 %
41.8
32.8
-19.0 %
40.5
33.5
-17.5 %
40.6
