Cooler Master
Noctua
Sickleflow 140 ARGB
NF-A14 FLX
195 g
210 g
650 U/min
900 U/min
1400 U/min
1200 U/min
67.0 CFM
68.0 CFM
113.8 m³/h
115.5 m³/h
2.25 mmH2O
1.51 mmH2O
27.0 dBA
19.2 dBA
Beige
Braun
Halbtransparent
Braun
5.5 V
4.6 V
2.9 V
4.2 V
599 U/min
381 U/min
495 U/min
469 U/min
1374 U/min
1199 U/min
45.3 CFM
+18.1 %
53.5 CFM
28.1 CFM
+17.4 %
33.0 CFM
26.1 CFM
+21.5 %
31.7 CFM
27.0 CFM
+11.6 %
30.1 CFM
77.0 m³/h
+18.1 %
90.9 m³/h
47.7 m³/h
+17.4 %
56.0 m³/h
44.3 m³/h
+21.4 %
53.8 m³/h
45.9 m³/h
+11.5 %
51.2 m³/h
+82.0 %
0.91 mmH2O
+82.0 %
0.91 mmH2O
0.5
0.5
+66.7 %
0.30 mmH2O
+80.0 %
0.09 hPa
+80.0 %
0.09 hPa
0.05
0.05
+66.7 %
0.03 hPa
35.5
-3.7 %
34.2
37.2
-12.7 %
42.6
32.8
-19.6 %
40.8
33.5
-16.0 %
39.9
