Cooler Master
Thermaltake
Sickleflow 140 ARGB
195 g
212 g
650 U/min
500 U/min
1400 U/min
67.0 CFM
58.4 CFM
113.8 m³/h
99.1 m³/h
2.25 mmH2O
2.41 mmH2O
27.0 dBA
22.3 dBA
Grau
Halbtransparent
5.5 V
2.9 V
599 U/min
391 U/min
495 U/min
413 U/min
1374 U/min
1950 U/min
45.3 CFM
+36.5 %
33.2 CFM
28.1 CFM
+11.4 %
25.2 CFM
26.1 CFM
+6.5 %
24.5 CFM
27.0 CFM
+29.7 %
20.8 CFM
77.0 m³/h
+36.5 %
56.4 m³/h
47.7 m³/h
+11.5 %
42.8 m³/h
44.3 m³/h
+6.5 %
41.6 m³/h
45.9 m³/h
+29.7 %
35.4 m³/h
+268.0 %
1.84 mmH2O
+62.0 %
0.5
0.5
+25.0 %
0.40 mmH2O
+260.9 %
0.18 hPa
+58.9 %
+2.0 %
+27.5 %
35.5
-5.1 %
37.4
37.2
-1.9 %
36.5
32.8
-8.9 %
36
33.5
-7.5 %
36.2
