Noctua
Arctic
NF-A14 FLX
P12 PWM
210 g
139 g
900 U/min
200 U/min
1200 U/min
1800 U/min
68.0 CFM
56.3 CFM
115.5 m³/h
1.51 mmH2O
2.20 mmH2O
19.2 dBA
Beige
Braun
Silber
Braun
4.6 V
4.2 V
3.0 V
381 U/min
207 U/min
469 U/min
547 U/min
1199 U/min
1748 U/min
53.5 CFM
+59.5 %
33.5 CFM
33.0 CFM
+41.8 %
23.2 CFM
31.7 CFM
+37.6 %
23.0 CFM
30.1 CFM
+39.9 %
21.5 CFM
90.9 m³/h
+59.5 %
57.0 m³/h
56.0 m³/h
+41.8 %
39.5 m³/h
53.8 m³/h
+37.6 %
39.1 m³/h
51.2 m³/h
+39.9 %
36.6 m³/h
0.91 mmH2O
+82.0 %
0.91 mmH2O
+49.2 %
0.5
0.5
0.30 mmH2O
+103.3 %
0.09 hPa
+80.0 %
0.09 hPa
+50.0 %
0.05
0.05
0.03 hPa
+100.0 %
34.2
-6.8 %
36.7
42.6
-18.5 %
34.7
40.8
-15.0 %
34.7
39.9
-13.8 %
34.4
