Noctua
Cooler Master
NF-A14 FLX
Masterfan MF120 Halo
210 g
180 g
900 U/min
650 U/min
1200 U/min
1800 U/min
68.0 CFM
47.2 CFM
115.5 m³/h
1.51 mmH2O
19.2 dBA
30.0 dBA
Beige
Braun
Grau
Braun
Halbtransparent
4.6 V
3.3 V
4.2 V
381 U/min
166 U/min
469 U/min
590 U/min
1199 U/min
1792 U/min
53.5 CFM
+116.0 %
24.8 CFM
33.0 CFM
+65.7 %
19.9 CFM
31.7 CFM
+56.5 %
20.2 CFM
30.1 CFM
+74.8 %
17.2 CFM
90.9 m³/h
+115.9 %
42.1 m³/h
56.0 m³/h
+65.7 %
33.8 m³/h
53.8 m³/h
+71.3 %
31.4 m³/h
51.2 m³/h
+74.7 %
29.3 m³/h
0.91 mmH2O
+127.5 %
0.40 mmH2O
0.91 mmH2O
+12.3 %
+25.0 %
0.40 mmH2O
0.30 mmH2O
+33.3 %
0.40 mmH2O
0.09 hPa
+125.0 %
0.09 hPa
+12.5 %
+25.0 %
0.03 hPa
+33.3 %
34.2
-9.5 %
37.8
42.6
-14.6 %
36.4
40.8
-10.5 %
36.5
39.9
-10.8 %
35.6
